Chungster wrote:Well it's not just me that's only realised today!!!Jane wrote:Chungster wrote:Amazing! My coming home lights work now. Gotta pull the flasher after ignition off and on door opening lights will come on. Switches off per the delay set in the MFD.You sure you're not blonde ?..
Men don't need to RTFM you see cos we know how to drive a car
Coming/Leaving Home Lights, Reversing Mirror Not Working
- Shaun
Re: Coming/Leaving Home Lights, Reversing Mirror Not Working
The thing is i did read it in the manual when i first got it, but it never really registered LOL
DAR
My coming home lights work without having to flash lights etc. Leaving home work auto too.
- Jane
Leaving home will cos switch set on Auto, coming home ... well obviously it can be done then ! It is annoying having to flash the lights for it to work.DAR wrote:My coming home lights work without having to flash lights etc. Leaving home work auto too.
- Shaun
There seem to be some odd changes floating around, i tried to get the big Speed in the MFD today by changing the Instruments to "Rest of the world" but it didnt add a large speedo on mine, and it does on others !DAR wrote:My coming home lights work without having to flash lights etc. Leaving home work auto too.
Well that's thrown a spanner in the works! Has your coding been changed??DAR wrote:My coming home lights work without having to flash lights etc. Leaving home work auto too.
- Jane
Off you go then.... hurry up we are waiting182_blue wrote:I am tempted to nip out with VCDS lol
DAR
I have not changed it. Light switch sat in Auto, and I kn ow they work, as I sometimes curse them when unloading the car post work, and they go off after the period on my DIS (20 secs I think)Chungster wrote:Well that's thrown a spanner in the works! Has your coding been changed??DAR wrote:My coming home lights work without having to flash lights etc. Leaving home work auto too.
Leaving Home work just fine too, I always open car at work when about 50 feet away to marvel at the Xenons...............Sad but true!
DAR
My Cent Electric coding.
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 D HW: 5K0 937 087 D
Component: BCM PQ35 H 011 0028
Revision: BE011001
Coding: 46100A389825E10040080080340048E643750B88737D8D60E48040000000
Shop #: WSC 00020 790 00000
VCID: 3667437938C1
Part No: 1K8 955 119 E
Component: Wischer 14110 22 0614
Coding: 009F95
Part No: 1K0 955 559 AH
Component: RLS 221209 05 54 0402
Coding: 0730ED
Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Part No: 1K8 951 605
Component: LIN BACKUP HO H10 9003
Coding: 000000
No fault code found.
Revision: BE011001
VCID: 3667437938C1
Coding: 009F95
Coding: 0730ED
Coding: 000000
Coding: 000000
- Shaun
Dar what does this look like on yours ?
09 Central Electrics module, using long coding helper
- Byte 12 - untick bit 2
- Byte 17 - tick bit 5
- Shaun
MineDAR wrote:My Cent Electric coding.
Revision: BE011001
VCID: 3667437938C1
Coding: 009F95
Coding: 0730ED
Coding: 000000
Coding: 000000
Revision: BE011001
Coding: 48100A389027E10040080080340048E643550B88736D8D60E48000000000
VCID: 36674B9F382F
Component: Wischer 23100 22 0614
Coding: 009795
Component: RLS 301109 05 54 0402
Coding: 0330ED
Coding: 000000
Coding: 000000
that's all techno babble.
Have u tried coding that bit to see if it works??
- Shaun
I did this and now it works as per Dar's :-) (like the Golf used to)
excellent.182_blue wrote:I did this and now it works as per Dar's :-) (like the Golf used to)
now i need to find someone local with VCDS lol.
It's so much better than having to flash the headlights. Shame it doesn't work on our Passat CC too.182_blue wrote:I did this and now it works as per Dar's :-) (like the Golf used to)
why wasn't it set like that from the factory???
stupid engineers!!!
stupid engineers!!!
DAR
I have just tested.
If i open the car, the LH lights activate, if i then lock the car, without opening the door or touching anything, the CH lights stay off.
I have unlock, and switch the ignition on (don't have to start the car) the CH lights activate.
I have not VCDS'd the car, long coding below, if Blue posts his pre and post codes we can do some investigations.
DAR's C/Elect coding: 46100A389825E10040080080340048E643750B88737D8D60E48040000000
I wonder if people got fed up with folk saying "you've left your lights on" when parking up - had that more than a few times when I had my Leon.Chungster wrote:why wasn't it set like that from the factory???
stupid engineers!!!
- Shaun
Mine is now like that tooDAR wrote:I have just tested.
