Hello sciroccofriends,
the register 4 is officially opened. You can find the NEW SCIROCCO under
Kartei4: Typ13. There have been already registered 149 entries through fairs,
events, test drives, etc. This is a good start and I am lucky about
each additional item. The owners of Corrado will certainly catch up soon, right?
First register on the management tool and then insert your item(s).
http://www.sciroccokartei.de/html/db/index.php
The new LOGIN for old entries works as follows:
Your email address used in your entry is of great importance.
Click the button REGISTER NOW. Enter your data. Once the registration
is complete you'll receive an email in which you will have
to confirm your registration. Only then can you log in.
http://www.sciroccokartei.de/html/db/in ... istrieren0
During REGISTRATION (or the first login) all vehicles entered by a user
will be assigned to that user. This works through the email identifier.
For this purpose you must enter the same email address during
login which you have originally provided to the Register. Because you
have to confirm the registration by email, you have then also confirmed
your email address. This ensures that only the right Sciroccos end
up in a user's profile. At a later date you can using the management
tool modify your data, club, HP, VIN, attach a picture of your Scirocco, Corrado, New Scirocco etc.
There is folder for uploading your picture. The picture will automatically
receive a red marker. The text is generated dynamically.
"Sciroccokartei.de Kartei 2:444" This marker would, for example,
mean Register #2 (because of the 53b), and number 444 denotes the entry
number in Register #2. The numbers have changed slightly because some of the old numbers
were used twice. All entries have now been correctly renumbered.
International entries are encouraged ...
Scirocco database
Scirocco database
Greetings Gregor
Re: Scirocco database
since 2018 the Sciroccokartei is closed.
Thanks for the entries and interests
Greetings Gregor
