Warning light- urgent advice please
bluedjlatte
Post by bluedjlatte »
Driving down from London to Somerset today in my 2009 2l diesel DSG Scirocco and the yellow engine shaped warning light came on. I have checked the manual and all it says is something along the lines of 'fault with the exhaust system refer to VW technician'.
I have to make the return journey tomorrow (Sunday)and will not be able to get to a VW dealer until Monday. Does anyone know what this light is indicating and will I be doing any serious harm if I make the return journey with it on?
All other dials and gauges on the dash are giving normal readings at the moment.
Would be grateful for any advice.
markfromworksop
Re: Warning light- urgent advice please
Post by markfromworksop »
It will be D.P.F. clogged. A motorway run at a light throttle opening should do the trick. Don’t run on supermarket Diesel treat it to some V Power or the like as you will get less soot in the exhaust gases.
bluedjlatte
Thanks for that. I didn't see your reply until after I made the return journey (without any further problems). The light is still on but nothing else seems to be affected. No funny noises and performance and fuel economy are ok. I will try what you say tomorrow and see if that clears it.
alexroc
Options: 2009 Spec with Premium mats, GT steering wheel badge, Fiscon Bluetooth Basic Plus, Cruise control
Post by alexroc »
I had exactly the same. It was a faulty exaust gas sensor on mine. It was replaced under warranty. If the light doesn't go out that's what it is. Nothing to worry about really. I think this is a common fault on all VW models as there was a dodgy batch of sensors. Mine is a 2009 model too.
bluedjlatte
I went to the local VW dealer first thing this morning for advice. I thought they might send someone out just to have a quick look over it but all they did was book it into the workshop. Anyway,a few miles down the road, after I had left the dealers the light went out. So, it sorted itself out, pretty much as predicted! I will keep an eye on it but as you say, it looks like it might be an intermittent fault with a sensor. The car still has a year of warranty left so I should be ok if anything does need to be changed.
Thanks for your help.
egobreed
Options: Nada!
Post by egobreed »
My Golf V 1.6 FSI had three separate faults with NOx sensors and ignition coils. My Scirocco's a couple of years old now so I'm just waiting for light to come on...
bluedjlatte
The light came back on today so it looks like I will be keeping my booking at the dealer for a couple of weeks time.
Digiman
Options: none
Post by Digiman »
I just had my exhaust gas sensor replaced on my Roc last month for the same problem.
