Sat Nav system
sedus2000
Options: sunroof
Sat Nav system
Post by sedus2000 »
Hi all,
Finally I've become the owner of R after 8 months waiting. It worths to wait! But at this moment I feel I had a mistake to an option. I just chose RCD 510 as a audio system, which doesn't include a sat nav. A common sat nav which is attatched on the front windscreen is not fitting well with my R. So I tried to change it into RNS510 however it's so expensive of it's own. It's over 2 grand.
So I'd like to ask you guys if there's better way to get it with some cheaper ways.
Or can you recommend another sat nav system better than RNS510 which is able to fit in scirocco R?
Shaun
Re: Sat Nav system
Post by Shaun »
Get one from ebay, usually around £500 to buy
sedus2000
Options: sunroof
Re: Sat Nav system
Post by sedus2000 »
If I could buy it from eBay, how can I install it? Is it available in the common garage? And does it affect to the warranty if I took it in the private garage? Thanks.
Shaun
Re: Sat Nav system
Post by Shaun »
sedus2000 wrote:If I could buy it from eBay, how can I install it? Is it available in the common garage? And does it affect to the warranty if I took it in the private garage? Thanks.
Its easy to install, it may need VCDS coding, obviously you wont get warranty on the RNS from VW , the ebay seller etc might give you warranty though, depends who you buy it from i guess.
sedus2000
Options: sunroof
Re: Sat Nav system
Post by sedus2000 »
Is it easy for me to install it myself? VCDS coding sounds like difficult and very technical to me. Hum
b0rk
Options: Used to have an R...
Re: Sat Nav system
Post by b0rk »
There are some eBay sellers that will fit it for you assuming your based the uk.
whicher
Options: 18" Interlagos, 2 Zone Climate, Cruise Control, Paddleshift, Colour MFD, Vienna Leather, Bi-Xenons, Winter Pack, Front Fogs, Sat Nav, Dynaudio, Tinted Glass, Bluetooth, Parking Sensors, Fixed Price Servicing.
Re: Sat Nav system
Post by whicher »
These guys look quite good but I've no experience of using them myself. Looks like they'll come to you was well if you're in the right place. :)
http://www.oemretrofits.co.uk/" onclick="window.open(this.href);return false;
Ordered: 27th February 2011
VW Confirmed Build Week: 13
Built: 28th March 2011
Delivered to Dealer: 21st April 2011
Pickup: 30th April 2011
Time from order to delivery: 2months 3 days :D
sedus2000
Options: sunroof
Re: Sat Nav system
Post by sedus2000 »
Thank you, guys.
I'm considering two installer which I've found in the Internet.
