Remote start
Remote start
hi does anyone know roughly how much a remote start will be for the Rocco thats if it can be done which i assume it can be??? i want it for my horrible cold early starts at work!
George
George
- bianco
Re: Remote start
Remote start would be experimental / a first
How about having a webasto or simular remote controlled oven installed? Can be timer controlled as well.
- juniorbanks
Re: Remote start
The Touareg has this as an option @ £785 which also upgrades the fuel tank to 100 litres. Not sure whats involved and how much you could use on a roc but maybe a dealer has more info. Obv you wouldnt get the uprated fuel tank unless you fancy losing your boot
- Shaun
Re: Remote start
Be aware that adding something like this yourself could completely invalidate your insurance.
Re: Remote start
Clifford remote start systems can be had for less than £200 I think
Re: Remote start
ive just browsed and seen them around that price and cheaper. i would love to do this to my rocco so if you find one that works can you let me know cost etc please. also will the car remain locked until you unlock it yourself? you dont wana help a car thief out!lol
Re: Remote start
thanks for the replies! i think im may look into the clifford one as ive known people in the past that have had them and they have been brilliant! yeah the car normally remains locked until you unlock it!
- Shaun
Re: Remote start
Read up on this first and check with your insurance, the use of inteli start used to require the removal of the current OEM imobiliser ( turning off with VAG Commander) or by sticking the Transponder from the key at the side of the ignition barrel, doing both of these will invalidate your car insurance, and the clifford is not (or wasnt) insurance approved when inteli start is activated (or even installed), proper minefiled, personally if i was a bothered as you seem to be about the cold mornings i would buy a proper pre heat system that does not use the car engine to warm the car.
Re: Remote start
There isn't an insurance approved aftermarket remote start system on the market. IIRC Thatcham require such a system to actively prevent drive, just leaving the doors locked is not acceptable.
Clifford Intellistart still requires the keyfob transponder to be hardwired into the system
Re: Remote start
My viper alarm in my previous car was thatcham approved and had remote start. The engine would start and run for 15 mins but the doors would remain locked and the alarm active. If you pressed the brake pedal to select a gear the engine would just cut out. Every insurance company accepted the alarm as they do for my dads Clifford alarm with remote start.
