Anyone runninng coilovers
Hi all i should be getting my R in march and just wondered if anyone is running coilovers?
the cars sit quite high standard,the kw's normally are highly rated is anyone running those?
Re: Anyone runninng coilovers
KW had a R on V3's with HLS on show at Autosport. Lowered by about 50mm...but i didn't take a pic of it.,
Don't think anyone has put collies on yet on a R. Set of Lowering Springs will do just fine really. Too many speed bumps around!
Strat
which KW Coilovers would you get?mattyw wrote:Hi all i should be getting my R in march and just wondered if anyone is running coilovers?
Rolling Deep...
when i spoke to KW a few weeks ago they said there R was on clubsports and HLS rather than V3s, the V3 kit is out as posted in this section before, the v3 kit has revised springs compared to the roc for the GT
some pics from autosport
i might just fit some h&r springs first
that KW R had 10mm spacers front and back too!!!
Scirocco R certainly doesn;t really suit OZ Super T's
Looks to be sitting a bit awkward aswell, drop the front a tad more and it'd be better.
polo classic
The KW rocco is about as low as my winter setting og H&R's
Strat
How does the adjustable dampers work with something like coilovers? intersted to know how that works in that, you have 3 settings, sport, normal and comfort. Anyone got any knowledge or experience what those settings are like post-coilover implementation?
Will sport become unuseable? Educate me!
Rolling Deep...
It doesnt work with coilovers.Strat wrote:How does the adjustable dampers work with something like coilovers? intersted to know how that works in that, you have 3 settings, sport, normal and comfort. Anyone got any knowledge or experience what those settings are like post-coilover implementation?
No one produces a coilover kit which is compatible with the OEM system, yet.
KW run a ACC delete gizmo so that u don't get any flashing lights on the dash when you run their coilovers.
- Shaun
They do indeedChungster wrote:KW run a ACC delete gizmo so that u don't get any flashing lights on the dash when you run their coilovers.
Strat
How does that ACC delete thing work then? Can it be easily put back to standard?Chungster wrote:KW run a ACC delete gizmo so that u don't get any flashing lights on the dash when you run their coilovers.
so to retain the ACC, you can only use springs?
do all companies (eibach, H&R, koni etc) use the same feature? or is KW the only set-up available for the R?
Rolling Deep...
