Scirocco Comprehensive Fuse Lists
The following fuse lists for the Scirocco are more comprehensive than the pre MY2010.5 (pre November 2009) owners handbooks contain. Post MY2010.5 model handbooks do not contain a fuse list.
The lists of fuses cover all circuits of all Scirocco models to date. They are universal lists for specific production periods. You may find some fuses missing from your Scirocco because they are specific, such as petrol v diesel engine or an order option is not fitted.
In reviewing I have found fuse amperage differences to the original information. If yours differs, then the fuse rating fitted overrides the one listed when replacement is required.
From the three Fuse List posts below, you should be able to match your Scirocco to two fuse boxes and download two files appropriate to the car.
All the fuses except for two specific fuses are located in two main Fuse Box panels.
- Under the bonnet in the rear left corner. To release the top cover, slide the two finger tabs on the rear edge forwards and lift the cover slightly forwards and upwards.
- Inside the end of the dash at the driver's side (Right Hand Drive or Left Hand Drive). To gain entry there is slot as indicated in the photo. Lever off the panel which is held by three stud clips.
Inside you will find a little fuse puller tool for both the mini and standard fuses that are fitted to the Scirocco. The larger fuses are easily pulled with your fingers.
Re: Scirocco Comprehensive Fuse Lists
The fuses on the Scirocco are divided into three main areas.
- Front vertical panel of the engine bay fuse box. Known as "SA" fuses by number, eg. SA1.
- Top panel of the engine bay fuse box. Known as "SB" fuses by number, eg. SB1.
- Driver's dash side panel fuse box. Know as "SC" fuses by number, eg. SC1.
Now to select your appropriate fuse lists from the three posts below. You need to identify two lists based upon the type of fuse box fitted and when the Scirocco was manufactured. At the end of your selection, you should have one for the engine bay fuse box and one for the dash fuse box in PDF file format............
Engine Bay Fuse Box "Type A"
This is the general layout of a Type A engine bay fuse box. The fuse box contains the "SA" & "SB" fuses.
These are the "SA" fuses hidden behind the plastic cover (yellow spots in the photo below).
These are the "SB" fuses on the top panel of the box.
If this Fuse Box layout represents your Scirocco, select one of the files below.....
Engine Bay Type A Fuse List for MY2009 Model Sciroccos with Chassis Numbers Scirocco Chassis: WVWzzz13z9V***** where * are digits.
Engine Bay Type A Fuse List for MY2010 onwards Model Sciroccos with Chassis Numbers Scirocco Chassis: WVWzzz13zAV4***** / WVWzzz13zBV0***** where * are digits.
Engine Bay Fuse Box "Type B"
This is the general layout of a Type B engine bay fuse box. The fuse box contains the "SA" & "SB" fuses.
These are the "SA" fuses.
If this Fuse Box layout represents your Scirocco, select the file below.....
Engine Bay Type B Fuse List for MY2010.5 onwards (Nov'09 onwards) Model Sciroccos with Chassis Numbers Scirocco Chassis: WVWzzz13zAV423*** onwards/ WVWzzz13zBV0***** where * are digits.
( A thank you to Chungster for taking the photos)
Dash Fuse Box
This is the general layout of the dash fuse box.
These are "SC" fuses on the panel.
Now select one of the files below.....
Dash Fuse List for MY2009 Model Sciroccos with Chassis Numbers Scirocco Chassis: WVWzzz13z9V***** where * are digits.
Dash Fuse List for MY2010 onwards Model Sciroccos with Chassis Numbers Scirocco Chassis: WVWzzz13zAV4***** / WVWzzz13zBV0***** where * are digits.
Two specific fuses are located away from the two main fuse box locations.
Fuse S44 – Electric Seat adjustment.
Fuse S83 – Sunroof on MY2009 models
To gain access to them, firstly open the driver's small drawer. Now squeeze the sidewalls (direction of green arrows) one at a time for the drawer to pass over the end travel stops.
With the drawer now fully open, pull it off it's hinges in the lower lip of the dash. Pull directly towards the driver's position – green arrows.
(The driver's small drawer clip onto hinges are in the red circles in next photo..)
This will reveal the relay panel and on the top on the in-board side are the S44 & S83 fuses, if these options have been fitted to the Scirocco. Circled in yellow.
These two fuse locations are listed in the Dash fuse lists where appropriate to the Scirocco model year (MY).
Excellent post RW1
- bianco
Fantastic info
Anyone for copy-pasting it to the Roccopedia?
Thank you both.bianco wrote:Anyone for copy-pasting it to the Roccopedia?
I'm sure it will get sorted to Roccopedia sometime soon along with some other things.
I'm from Germany, but I must say this is ... after a long search ... the best information I found.
Many thanks, a very good work !
- I drive a: R-Line
hi which one is my rear wiper relay please
Solved my problem with an intermittent fault in the rear wash/wipe. Opened the boot and closed it again!
Rear wash/wipe won't operate if the boot is open. There are two spring loaded buffers - one each side half way up the boot door. A squib (as my Dad used to say) of WD-40 into each and a little in-out exercise to make sure it's got well in, then make sure the boot is firmly shut.
One at least of these must have a switch in to isolate the rear wash/wipe when the boot is open.
I've had a good look through the SC fuse listings for my 2013 140 TDI Scirocco. I can't illuminate the rear registration number plate at present. I have two new bulbs, but the old bulbs do look okay. I would like to check the relevant fuse, but can't find it on the listings.
Any help is appreciated.
Kernowman
Kernowman
- Jimijokela
I need help!
My side mirrors wont move when i try to adjust them. Cant find their fuse?
- thecrofter
Anyone got an up to date Fuse List - particularly for the 2014/15 face lift models
2.0 TSi 280 R DSG Rising Blue / April 15 - 11 March 20
2.0 TDi 170 DSG R-Line Indium Grey / June 12 - April 15
2.0 GT TDi 170 DSG Salsa Red / May 10 - June 12
Fuse 28 in driver side bay is supposedly the RNS510, i take off it but the nav still works... I want to cut the energy for this because i have a problem...
What is the fuse for rns510?
SB8 to bay engine (15A), i guees it woild be inside.
Thanks!
Thanks!
kernowman wrote:I've had a good look through the SC fuse listings for my 2013 140 TDI Scirocco. I can't illuminate the rear registration number plate at present. I have two new bulbs, but the old bulbs do look okay. I would like to check the relevant fuse, but can't find it on the listings.
Kernowman
Hi mate, I know it's a long while since you posted about your number plate lights but did you find which fuse it was as I'm having the same problem with mine and I just can't get it sorted?
- In: Pure White
Great info here, this thread need to be sticky.
- Steamahead
- I drive a: GTS TSI
Lumber Support fuse gone -
I'm a newbie here and only owned mine a few days. Having found out I could not adjust my lumber support... I popped on here and can report I had a blown fuse. So thank you very much for the useful tip.
Soon to be an owner..
Has anybody got the fuse diagram list for the 2009 scirocco as the link posted on here no longer works thanks
