Hi all,
hopefully this hasn't been covered already, if so sorry (I did have a quick look in the search function).
Can a second display be connected to the RNS510? I want a screen in the back of the car. If this is possible and someone has it set up already, can you tell me what, if any functionality issues you've had.
Al
RNS510 2nd Display????
________________________________________________________
Build Week 44
Fri 30th Oct, dealer confirmed built & waiting to get on the boat
Build Week 44
- Shaun
Re: RNS510 2nd Display????
It is possible and i have seen it done on a golf, i will try and find a link for you.
PS on some models there is an expensive factory option called RSE (rear seat entertainment) which involves two rear screen in the back of the headrests
The link below should provide some guidance on a retro fitted RSE system..
http://www.my-gti.com/525" onclick="window.open(this.href);return false;
Thanks mate. Probably a more expensive solution than I can justify for the amount of usage, but it does look wicked.
Build Week 44
Build Week 44
