Hi guys
Was looking in there this morning and noticed a switch of sorts in the glove box - upper right hand side - looks as if it can be turned?
Any idea what this is for?
Glovebox
Re: Glovebox
in the glove box is the passenger airbag switch, could be that.
Re: Glovebox
trix wrote:in the glove box is the passenger airbag switch, could be that.
Or turning on/off the air conditioned glove box
Re: Glovebox
yep, there are a few things it could be, the airbag switch was just the first that sprung to my mind...
Vee do you keep your laptop on the manual shelf rather than the instruction manual then?
- Shaun
Re: Glovebox
I have airbag switch and tyre pressure monitor switch there on mine, there is also the vent opening for the air con too
- bianco
Re: Glovebox
If You mean a knob of sort, then You turn it one way to let cold air from the aircon flow to the glovebox (a finger size hole). Turn the other way to close.vee wrote:Hi guys
