RNS 510 - no directions on MFD (version B)
Can anyone help me find out why there is no information on the MFD display when I have the nav system working, the Scirocco is new (1/9/10) but the nav unit came out of my mk 6 golf where it worked perfectlly with direction arrows, road names and diection the car is pointing eg north, south etc on the MFD.... is it going to be a trip to the stealers or is there anything I can do?
- stuaz
Re: RNS 510 - no directions on MFD (version B)
Im guessing something has to perhaps be enabled in VAGCom for the MFD to display it? Or maybe its a different computer with the sat nav models (but i doubt that).
Our more knowledgable VAGCom users will surely confirm
Now a Proud Owner!
yeah needs some gateway business adjusting with VCDS... I have the same issue was hoping someone lived in the Horsham West Sussex area who might be able to assist me for a beer voucher or two... :-)
Thanks for your help up to now, still need to confirm this, I love the car, just hope it does not end up like my MK 5 R32(S) did (before my mk 6 golf) and end up with the scum that tried to pinch them!
Could you please give me some more details (screen shot would be good) on this. tried looking for the right option on VCDS but couldn't see anywhere to turn it on in the MFD??182_blue wrote:As above , needs a tick in the gateway via VCDS
Thanks,
TR.
- Shaun
Is your Nav a C version ?, you need to ensure BAP is enabled in device (Navigation) 37, byte 7 bit 7 , check this after you have enabled Navigation 37 in the Can Gateway
You may need to reboot the RNS afterwards too
- Shaun
Here are some screen shots and help bits i borrowed from Morty :-)
You need to go into Can Gateway I think its controller 19, on the controller screen go into the Installation List and go half way down the page to controller 37 and tick this then Save Coding, Go out of the controller.
Go into controller 37 Navigation and then into Coding and then Long Coding:
Byte 0 The first 2 boxes should not bit ticked, Unless you have CD changer/MDI media in or Aux in
Byte 1 This is for the sound system if you have an AMP installed or if you have Dynoaudio installed from factory:
Byte 2 This is how many channels you have working i.e front or back or front and back:
Byte 3 This is for the Mic Diagnostics if you have voice control and also if you have the badge camera in the back like a couple of people,
Byte 4 This is for speaker monitoring just incase there is a problem on one of them:
Byte 5 Is for the manufacturer speaker arrangement, this should be set to Linear for the VW's
Byte 6 This is not used in the coding:
Byte 7 Some of the bits in this Byte you may not have if your using f/w 1100 or lower but this is for MFSW, screen colours and comms to the highline. None of them should be ticked unles you have a mk6 golf or dont have voice control.
Hope this helps and just one more thing you cannot use any version of VCDS lower than 9XX
Darren
Darren
Yes mate it's a C version. Thanks for the instructions :-) I'll go and try it shortly.182_blue wrote:Is your Nav a C version ?, you need to ensure BAP is enabled in device (Navigation) 37, byte 7 bit 7 , check this after you have enabled Navigation 37 in the Can Gateway
You may need to rebbot the RNS afterwards too
Many thanks, it's much appreciated.
All sorted mate
easy when you know how ;-)
- Shaun
true romance wrote:All sorted mateeasy when you know how ;-)
good good, was it the BAP ?
No that was already selected, just needed to tick the nav box in the installed items list. Once again thanks.182_blue wrote:true romance wrote:All sorted mateeasy when you know how ;-)
Hello i have build in a rns510 in my rocco
But de white display isnt showing navi or audio
With vcds 12.12 I checked navigation in installed option
(It was on allready)
And now i go in navigation and try to
Turn on byte 7 bit 7
Communication instrument cluster via operation
And display protocol (bap)
But it keeps giving me the same error
This equipment nr is invallid!
Equipment number must be 5-6 digits 00000-262143
Can someone please help this is realy frustrating!
Thanks alot!
Thanks alot!
Solved ! Had to put a workshopcode enz in the option menu
