Kev
Administrator
Posts: 5069 Joined: Fri Jul 25, 2008 5:25 pm
Options: Leather, cruise, parking sensors, folding mirrors, flat tyre indicator Sadly replaced now by an F-Type.
Post
by Kev » Sun Aug 29, 2010 6:24 pm
Scirocco Common Questions
Some of the more common questions.
How can I turn my DRLs off? Link
Should my car come with an iPod cable? Link
What is the VW build week system for working out when my car will be made? Link
How long will it take to arrive? Link
How can I find out where the boat is with my car on? Link Link2
What's the metallic rattling noise at 2000rpm? Link
What should I check on delivery? Link
bjorsvik8
Posts: 2 Joined: Sat Sep 06, 2014 9:07 pm
Options: 19" wheels
Post
by bjorsvik8 » Sat Sep 06, 2014 9:39 pm
Can anyone direct me to a good source of photo's of scirocco's with different wheels especially ??
whiteDevil_170
Posts: 2753 Joined: Sat Sep 17, 2011 5:39 pm
Options: 19 inch lugano alloys , Metal pedals, satnav , DAB , leather , parking sensors , Red footwell LEDs , white led interior , hkb door sills , Needle sweep ,Horn beep on open/close , big speedo, drl deactivated, cornering fogs, An ocd for keeping it clean! Gloss black mirrors. revo stage 1 remap
Post
by whiteDevil_170 » Sat Sep 06, 2014 9:42 pm
google images???
or have a look around the showroom thread
Jack
Lets Roc
bjorsvik8
Options: 19" wheels
Post
by bjorsvik8 » Sat Sep 06, 2014 9:45 pm
Where do I get the showroom thread ? Old fart don't you know, bit of a technophobe
whiteDevil_170
Post
by whiteDevil_170 » Sat Sep 06, 2014 10:12 pm
Jack
Lets Roc
Phil
Posts: 1588 Joined: Tue Sep 04, 2012 10:34 am
In: Night Blue
Post
by Phil » Thu Apr 23, 2015 11:09 am
can we add the iphone issues to this? Seems to be a common thing asked these days along with noisy engine chain tension etc
Phil
whiteDevil_170
Post
by whiteDevil_170 » Thu Apr 23, 2015 11:55 am
Also has my car got bluetooth should be added. I think this should be made a sticky. I also think this should be renamed most common questions asked.
Jack
Lets Roc
Lowlife
Posts: 18 Joined: Mon Apr 13, 2015 6:02 pm
Options: None
Post
by Lowlife » Tue Apr 28, 2015 7:10 pm
Turning the drl's off on my late 2009 rocco, followed the step by step how to, using the indicator stalk with no joy
Bomma777
Posts: 18 Joined: Fri Jun 12, 2015 12:29 pm
Options: Everything
Post
by Bomma777 » Mon Jun 15, 2015 7:25 pm
Does anyone know where i can get a front lower grille that is slatted?
Dave7692
Posts: 134 Joined: Fri Jul 11, 2014 3:38 pm
Post
by Dave7692 » Tue Jun 16, 2015 12:58 pm
Bomma777 wrote: Does anyone know where i can get a front lower grille that is slatted?
That would either be an 'R' grill or a modded T5 grill. An R grill will only fit into the R shaped bumpers. The T5 is a standard grill with the honeycomb cut out and the slats cut from a badgeless T5 grill glued in, then usually smoothed and painted.
If you google "Scirocco T5 mod" you'll likely find a thread with a better description and photos.
FredBloggs46
Posts: 23 Joined: Fri Nov 13, 2015 9:19 pm
In: Salsa Red
Options: HID's, VCDS tweaks, interior & number plate LED's, DTUK stage 2, Kenwood head unit, black VW badges, covered cup holder, H&R springs, BCS Rear exhaust, OCD detail by the man himself.
Post
by FredBloggs46 » Sun Nov 29, 2015 8:06 pm
philjay92 wrote: can we add the iphone issues to this? Seems to be a common thing asked these days along with noisy engine chain tension etc
IPhone issues, what are they then? Use both a genuine VW Mdi cable with the 30 pin end for iPhone 5, for the 6 add the 30 pin to lightning connector. Makes sure it's an original Apple adapter otherwise it won't work.
Tested in both 59 plate and 63 plate Rocco's
Nick123
Posts: 6 Joined: Fri Dec 25, 2015 8:08 pm
I drive a: 1.4 TSI 122/125
Options: Parking sensors front rear, Auto lights, Auto wipers, Sat Nav,
Post
by Nick123 » Sat Jan 02, 2016 8:45 pm
Anyone else when trying to upload pictures comes up with invalid?
Kev
Administrator
Post
by Kev » Sun Jan 03, 2016 12:15 pm
Quota limit is probably getting close. I've just increased it. You can host images on 3rd party sites like imgur though, then it doesn't use up our bandwidth and you don't have to much about with attaching.
brianlach
Posts: 4 Joined: Mon May 30, 2016 12:13 am
Post
by brianlach » Mon May 30, 2016 9:39 pm
Hello, can somebody explain me the difference between 137 or 137, 138. Or how can I know which one I have. Thanks.
mackie01
Posts: 132 Joined: Sun Jul 26, 2015 2:00 pm
Options: 19''Black Luganos, Sunroof, Cruise Control, Heated Leather Seats, Bluetooth, RNS510, Mudflaps, Dynaudio, Bootliner, Pressed Plates And a few other mods http://www.sciroccocentral.co.uk/forum/ ... 13&t=20294
Post
by mackie01 » Mon May 30, 2016 10:50 pm
brianlach wrote: Hello, can somebody explain me the difference between 137 or 137, 138. Or how can I know which one I have. Thanks.
I could be wrong, but I'm sure all the pre-facelift Scirocco's are model 137, and the facelift from the end of 2014 are 138
brianlach
Post
by brianlach » Tue May 31, 2016 4:56 pm
mackie01 wrote: brianlach wrote: Hello, can somebody explain me the difference between 137 or 137, 138. Or how can I know which one I have. Thanks.
Oh thanks, mine is 2014, I should check out the serial number, maybe I can get some info.
Rapidrc
Posts: 1 Joined: Sat Oct 14, 2017 12:34 pm
Post
by Rapidrc » Sat Oct 14, 2017 12:41 pm
Afternoon all which wires do I tap
Into for the puddle lights please
Kev
Administrator
Post
by Kev » Sat Oct 14, 2017 3:05 pm
Probably better off posting a new topic here
http://www.sciroccocentral.co.uk/forum/ ... m.php?f=39 " onclick="window.open(this.href);return false;
SciroccoCW
Posts: 270 Joined: Fri Aug 11, 2017 1:18 pm
In: Oryx White
Options: 2015MY, Bi-Xenon, 18" Interlagos, Start/Stop, Bluetooth, Sat Nav, Panoramic Roof, Parking Sensors, Heated Seats, Interior LED's, Projector Puddle Lights, Mudflaps, Winter Pack, Rubber Mats, Stainless Steel Pedals, VCDS Tweaks
Post
by SciroccoCW » Mon Oct 16, 2017 10:25 am
Rapidrc wrote: Afternoon all which wires do I tap
Was pin 18 and 19 on the door controller module for mine
http://www.sciroccocentral.co.uk/forum/ ... 39&t=24857 " onclick="window.open(this.href);return false;
vladandrei51
Posts: 91 Joined: Thu Jun 21, 2018 9:19 am
In: Night Blue
Options: REVO Stage 2 Wossner Forged Pistons Fox Sportauspuff Quad-Exhaust VWR VW Racing CAI 3" catless downpipe & 3" catback (custom) S3 intercooler De-Cat / De-Res 03C906036M Injectors NGK BKR7EIX Spark Plugs NGK U5002 48003 Coil Pack Revised Timing-Chain
Post
by vladandrei51 » Wed Jun 27, 2018 8:52 pm
Thinking about replacing the tensioner with the one with the OEM code 03C109507BA from VW in order to prevent timing chain failure. Is that the latest revised tensioner? Would it fit in 09 1.4 TSI 160 hp?
