I want to use the iPhone in conjunction with my pocketgpsworld subscription to spot speed cameras as the RNS doessn't have this function. As such I want the phone mounted fairly high on the dash board so I can easily see the warning, similar to a sat nav location.
I've looked at the Broadit options, the one that clips into the side if the head unit will be too low down. The other higher mounted one seems to cover one of the air vents which I'm not too keen on.
I guess the other option would be to use one of their windscreen sucker mounts then attach the custom iPhone holder to it.
Any other suggestions out there?
