oil temperature
Menasheh
oil temperature
Post by Menasheh »
What is the normal range for the oil temperature on TDI 170??
pafa
In: Sumatra
Options: Winter Pack
Sports Pack
Cruise Control
Parking Sensors Rear
Electricable Foldable Door Mirrors
Carpets
Exterior Badge Deletion
RCD 510 Dynaudio Soundpack
Flat Tyre Indicator
2 Zone Electronic Climate Control
Rear Tinted Windows
Re: oil temperature
Post by pafa »
90-100 on normal roads and highways...
If you put the pedal to the metal - 100 - 110
Had mine as high as 114 on a highway run....
Sanders83
Options: Bi-Xenon lamps
Re: oil temperature
Post by Sanders83 »
Is that the dial on the dash to the left of the fuel? Always thought that would be water temp?
RW1
Legend
Hi from Sunny Stopfordia
Re: oil temperature
Post by RW1 »
Sanders83 wrote:Is that the dial on the dash to the left of the fuel? Always thought that would be water temp?
Oil temp is only available on the computer (MFD) in the centre of the dash unit. It is only available if your Scirocco has the "Highline" computer. Selectable via the Multi-Function Steering Wheel right hand switch buttons.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
Sanders83
Re: oil temperature
Post by Sanders83 »
How would I know if I have highline? Cheers
RW1
Legend
Re: oil temperature
Post by RW1 »
Sanders83 wrote:How would I know if I have highline? Cheers
Looking at your order >>>>>>>
GT spec. has the Multi-Function Steering Wheel as standard so Highline will be on board. Standard models don't unless you spec a MFSW.
Sanders83
Re: oil temperature
Post by Sanders83 »
Cool, that'll be me sorted then. Cheers
