![Image](http://autoplus.de/images_tooltip_vw/climatronic_golf6.jpg)
(New Climatronic panel, as in Golf VI).
Nope, that's not it.Hatter The Mad wrote:Left, right, both?
So would this be useful to quickly cool down / heat up the car as you start driving? Does it switch back to low air flow after a while?adiq wrote:First is low air flow, second high flow auto mode.
I think I can answer that onespamdog wrote:...now, if anyone knows what the light under the "A" is on the recirculation button i would be grateful, have no idea how to get it lit or what it does!
(second button from the right on the top row)
Ahh, thought it might of been but as it didnt light up when i pressed it wasnt sure.martdy wrote:I think I can answer that onespamdog wrote:...now, if anyone knows what the light under the "A" is on the recirculation button i would be grateful, have no idea how to get it lit or what it does!
(second button from the right on the top row)![]()
It's the air recirculation control .First press is on (to prevent fumes entering the car). Second press is for automatic recirculation . Air quality sensor will switch to recirculate when it detects fumes![]()
God I'm sad ! I've spent to much time
No. The 2nd light lights up when you press it the 2nd time to show the auto recirc is active.spamdog wrote:Ahh, thought it might of been but as it didnt light up when i pressed it wasnt sure.
So the light will come on when fumes are detected i guess
So it does, need someone to crack a fart in front of me now to see if it works!awesum wrote:No. The 2nd light lights up when you press it the 2nd time to show the auto recirc is active.spamdog wrote:Ahh, thought it might of been but as it didnt light up when i pressed it wasnt sure.
x 2mannors007 wrote:Thanks Trix, thats spot-on and very useful to know!
