I have taken delivery of my car and something i've noticed after parking it after a gental ride, ie not reved past 4000rpm. Water temp is at 90 Degrees, oil temp at 100 Degrees. After parking the car the cooling fan switches on for over a minute? Outside temp 25 Degrees.
Is this normal with other owners. I had a Golf 5GTI prior and the cooling fan only came on after driving the car really hard.
Should I be concerned or not?
2.0TFSI Cooling Fan Paranoia
Re: 2.0TFSI Cooling Fan Paranoia
^f
Thanks, yes i'm South African based. It is 25 Celsius, but the is this a common issue as mentioned this had never happened before on my GTI the fan would rarely activate unless really driven hard.
vwchico, are you in Johannebsurg?
Wazzsta
2010 CW Scirocco 2.0 TSI REVO stage 1
- 35mm H&R springs
- APR Carbonio air intake
- 35mm H&R springs
Yes Johannesburg based....
