Worry about nothing, maybe!!!
Drigbyy2k
Options: Bi-xenon headlights... Flat tyre indicator... Winter pack... Door sills... Metal pedals... Aftermarket alloys...
Location: Highlands of Scotland (15miles south of John O'Groats)
Post by Drigbyy2k »
Just realised something that might a problem or might not...
I have ordered the flat tyre indicator, will having aftermarket alloys fitted effect this, ie stop it from working???
Cheers guys...
TimM696
Options: RCD-510 with dynaudio, sports pack, climatronic, interlagos rims, acoustic parking sensors, folding mirrors and rain sensor
Re: Worry about nothing, maybe!!!
Post by TimM696 »
It will work, the indicator does not measure pressure it measures the circumference of each tyre and when the circumference decreases it will indicate a flat tyre
christof
Options: Cruise control, folding mirrors and tyre pressure indicator.
Post by christof »
TimM696 wrote:It will work, the indicator does not measure pressure it measures the circumference of each tyre and when the circumference decreases it will indicate a flat tyre
Clever!
Scirocco Bhoy
In: Sumatra
Options: Parking Sensors, Premium Mats, Dynaudio
Post by Scirocco Bhoy »
What if you change the size of your wheels?
for example if you go from 17" to 19" or vice versa? Will the circumference not increase/decrease?
trix
Ordered 23rd June 09
Build week 41
Handover 17th Oct 09
Missing RW1
Post by trix »
it works on the rolling radium/circumference not the size of the rims, if you change your rims form 17" to 19£ for example you would be using lower profile tyres on the 19" compared to the 17" otherwise your speedo would be out.
if you did change your wheels then it would probably be sensible to check the pressures were right once fitted & then set the tyre pressure indicator system, its only one push of a button
