Just took delivery of the Roc and have decided to go down the USB HDD route instead of Ipod - not sure if I made the right decision
I am using a WD Elements 250GB 2.5" USB HDD and have loaded all my music (7,000 tracks / 50GB) arranged in folders as follows: -
Alpha Band (e.g. A to E)
Artist (e.g. Coldplay)
Album (e.g. X&Y)
Track (e.g. 04-Fix You-Coldplay.mp3)
I have placed a single track in root to allow me to play this then press 'MIX' with the subfolders option ticked in the config. This in theory should allow 'MIX' to work across all tracks.
My problems are as follows: -
1. The unit starts playing from the first track each time you start the car i.e. it does not resume from last track
2. The 'MIX' function does not appear to be very random - going through the tracks in order but missing say a few hundred out at each press of the next track button THEN after about three or four tracks the RCD510 locks up and you have to switch off at the ignition.
My next thought was to copy all 7,000 tracks to an additional top level folder called ' All Tracks' to allow 'MIX' to just work in one folder. However I shouldn't have do do this as it should be a standard feature. My husband's Civic does this operation perfectly across all folders/tracks on a CD containing MP3s.
Can anyone help resolve any of these issues?
Mary
