HANDSFREE CONNECTION
Hi recently purchased a 2013 Rocco and tried to connect my phone via the blue tooth.Cutting a long story short apparently after checking out the PR codes it shows it didn’t come with Bluetooth
Has anyone had the same problem and is it possible to have it reprogrammed so I can connect my Bluetooth don’t want to change the head unit HELP !
1.4_tsi
- In: Flash Red
Re: HANDSFREE CONNECTION
Which head unit is fitted and does it have a phone button? What is the model year identifier of the car - 10th character of the VIN?
Hi and thank you for the message car is registered 09-06-2011 Scirocco GT Bluemotion Tech TDI B is the tenth character of the vin it’s the standard stereo that came in the car
1.4_tsi
- In: Flash Red
2011 year, so an RNS 510 maybe, but there are quite a few variants From a quick Google search, it seems these systems require a separate Bluetooth module located under the front seat, but I'm no expert on this.
The exact factory spec for your car is available on Partslink24 - feel free to PM me your VIN if you'd like me to check, as I currently have a subscription
1.4_tsi
- In: Flash Red
Thanks for your PM. I'll post here as others may have better insight. Partslink24 shows your car was factory fitted with a RNS510 head unit, part number 1T0 035 680 C (current list price £4,610+VAT!).
The car wasn't fitted with the unit described as "Interface box with integrated control unit for telephone and 'Bluetooth' aerial" (of which there are many variants). I'm guessing this is the unit that would sit under the front seat if you had Bluetooth. To retrofit, you'd also need the mounting bracket/cover for the BT unit, and no doubt an interface cable between the BT unit and the head unit
