Hi all,
Have a 2011 2.0 140 HP GT diesel scirocco. Can someone give me a heads up where I’d find the Air Quality Sensor which has thrown up a fault. From looking online I thought it was under the right hand side scuttle panel when looking in from the front of the car. Nothing that resembles the new sensor to be seen.
Thanks for your help,
Nigel
Air Quality Sensor location
Busdriver947
1.4_tsi
- In: Flash Red
Re: Air Quality Sensor location
You're pretty much there. Under the passenger side plenum chamber cover, there is second cover that diverts water away from the air intake grille. The air quality sensor is mounted on a bracket attached to the air intake grille
Busdriver947
Thanks for the reply.
Found it, job done!
Really appreciate your help.
Nigel
Found it, job done!
Nigel
767Hunter
- In: Flash Red
Glad you found it, those sensors are easy to miss if you don't know exactly where to look under the scuttle.
