Long story short, window regulator replaced but the glass is a couple mm low. (I know about the holding the switch thing, it's not that, it needs adjusting, not just a reset)
My question is, is it done like this:
i.e. long torx up through the hole in the bottom of the door
or this:
i.e. door card off, loosen the screws holding the glass, fiddle it into place, retighten
Anyone know which is correct?
Adjusting window glass hright
1.4_tsi
- In: Flash Red
Re: Adjusting window glass hright
The first is correct for height and angle adjustment. I'm guessing this is from a VW training video. The second is only correct for back-to front adjustment
Dimbit
I think the first video is basically this, page 13:
https://drive.usercontent.google.com/do ... t=download
Done now but for the archives, things that would be handy to know first:
It's a T25
You need a very bright light to see what you're aiming for through the tiny hole. You absolutely cannot see it, illuminate it and get a screwdriver to it at the same time.
It's possible that I don't know right from left, but what I have called clockwise all my life moved the glass up, not down.
It's a T25
