Is this an mot failure the shocks are in perfect working order no leaks and secure. This indicates a sensor has has failed,however you will have a normal working shock absorber system ,in the fail safe position,perfect working order. You will lose the ability to set hard or soft suspension.
Will my car fail an MOT for this. Anybody priced sensor replacement ,Which i will do at a later date
Thank you
adaptive chassis control light flashing
miriam2elsa
