Need some advice please
My scirocco had a few lights pop up on the dash, I used an OBD scanner that said the rear left ABS sensor has an issue. I bought a new ABS sensor, installed it and the lights were still on the dash. I thought it might be faulty and gave it back. I bought another ABS sensor (febi bilstein) and changed the sensor again. Took the car for a drive and it started juddering. Live speed data shows that the rear left was fluctuating between 50kmh - 200kmh. I took it out and switched it with my the ABS sensor that was originally installed, its stopped the juddering but the car is still in limp mode and the dash lights are still on. I have also changed the wheel bearing but unfortunately it hasn’t. The car is currently in limp mode and I have no idea what to do. Any suggestions? (TIA)
