Do these discs need replacing + is the pattern wear normal?
amcridge
In: Salsa Red
Options: Navigation, Pan roof & BlueMotion.
Post by amcridge »
Rear brake discs usage/ wear.
Today, I noticed the front discs are shiny & used across the full diameter, without any rusted outer circumferences.
But the rear discs have an outer circumference that appears not to have been in contact, ever, with the pad.
I appreciate the braking bias for the front, but Is this normal?
1.4_tsi
I drive a: 1.4 TSI 122/125
In: Flash Red
Options: Factory fitted:
Parking sensors, front and rear
Electric folding mirrors
Smoking pack
Retrofitted:
Cruise control
Re: Do these discs need replacing + is the pattern wear normal?
Post by 1.4_tsi »
Yes, perfectly normal, with relatively light, ie non-urban driving. With that level of rust, no concern, but check the rear face as well. Your MOT tester and/or vehicle technician may note it as an advisory
