Can anyone help me iv just installed the TPMS reset button but it doesn’t seem to work. I’m not sure if it’s the wiring or the coding. The wiring I did is
ESP button
I took out the following pins and placed them in the little black connector that comes with the kit.
ESP button Pin 3 Brown to pin 3 on the little black connector
ESP button Pin 6 Grey to pin 1 on the little black connector
ESP button Pin 5 green/purple to pin 2 on the little black connector (this is the wire I’m not sure about as iv seen someone with a golf mk6 use the black/green wire)
TPMS button
The wires where labelled:
Braun = brown
Grau = grey
Schwarz = black
Brown wire into pin 3 on the ESP button = Brown
Grey wire into pin 1 on the ESP button = Grey
Black to pin 5 on the ESP button = Green/purple
The coding I did was in the ABS module byte 16 bit 2 the code got accepted ok and flashed on my dash then off.
But I get an error code when I scan the car the code is 01325.
Be a great help if anyone knows what iv done wrong.
TPMS help!
Re: TPMS help!
theres 2 codings you need to do not just one.
I offer Power fold mirrors installs, Cruise control installs, Coding, mirror folding on keyfob etc. i'm in Stockport,Manchester
Re: TPMS help!
What’s the other code do you know it? The warning light came on today but the button didn’t do anything could that be because I haven’t fully coded it?
