Need some help!
Iv got a crunching noise when coming off the clutch and accelerating. Once I’m up past 5mph the noise seems to go. But this doesn’t happen every time I pull away. Iv had a lot done to it:
•used gearbox replacement
•new clutch kit
•NSF wheel bearing
•OSF outer drive shaft joint
•engine rebuild
The noise was there before and after all these parts were replaced.
It seems to be coming from front right but I’m not 100% sure. My partner seems to think it’s worse when the engines cold and goes when the engines warm.
Any ideas?
Crunching noise when accelerating
Re: Crunching noise when accelerating
Are you sure it’s a crunching sound? Everything I would suggest you have already replaced. The only other thing I could possibly think of if the sound may be a creaking sound could be a suspension bush or something simple like that?
