Hey guys,
I am recently having this issue that my interior roof lights dont turn on when opening the doors. They do not work with both doors. Front and back lights. I can put them all on with the switch, then they work just fine.
Foot lights are working. Does anyone know how to fix this??
Which fuses do i have to check?? Or any other possible connectors.
HELP! Interior lights don't work
Re: HELP! Interior lights don't work
I apologise if this sounds patronising but double check the switch in the roof console is in the correct position. It has 3 positions,
1. Off
2. On with door operation
3. On.
If it's not that it's unlikely to be a fuse otherwise the lights wouldn't work at all. Only other thing I can think off is the door module but it's very unlikely both would fail at the same time plus the car graphic in the MFD wouldn't show an open door as an open door would not be detected plus the lights on buzzer wouldn't work either.
1. Off
3. On.
- In: Dark Oak
Yeah no problem, @CuprabobCuprabob wrote:I apologise if this sounds patronising but double check the switch in the roof console is in the correct position. It has 3 positions,
1. Off
3. On.
The switch is On with door operation, when i change it to on the lights will glow.
I have changed the roof console for a new OEM one but it didn't fix the problem. Just for sure maybe the switch contact points were bad.
Any other ideas?
Verstuurd vanaf mijn AC2003 met Tapatalk
I'm having the same issue as yourself. Looked on Internet and you tube no answers Have you had any joy
I have a 2009 tsi scirocco and none of my interior lights work. Any help would be much appreciated.
If all of the lights failed at the same time then it’s likely to be a fuse unless someone (usually a child pressing buttons and flicking switches) has turned them off by accident.
