Hey,
I figured this would be the best place to figure out what's wrong with my car, It is a Scirocco 2.0 TSI from 2009 (09).
I bought this car recently and it has a judder on startup and while at idle which has gotten worse recently, I have replaced the PCV which I have been recommended to do but still the same issue persists I have taken a quick look around the pipes and nothing seems to be cracked or burst and the car went from throwing the error codes: P0171 which has now disappeared and it's now displaying P0300, P2711, P0303, P0302.
I have no clue where to start and would desperately need advice.
Thank you
Car has very rough idle
Re: Car has very rough idle
Hello, could be worth checking the plugs and also maybe worth replacing the coil packs, seen on here that the Red R8 ones are good, have a look at the Awesome GTI website, hope this helps !!
