Hi guys, so after a few months of my Scorocco being idle(due to me being abroad then having to change the clutch), it's back on the road. However I have two error codes P0123, P2100, and the glow plug light flashing. I know you need VCDS to pinpoint the exact problem, however I thought I'd ask here first in case someone had it before.
With rona it's harder to get access to VCDS, and I'm quite handy with a wrench, so I'm open to suggestions. I was thinking of taking off the throttle body and cleaning that, maybe it's a bit stuck or something due to not being used in a while.
Fault codes help!
ryanv114R
Fault codes help!
