hi can anyone tell me what's needed when fitting passat hubs and arms? can i use my original scirocco ball joints and track rod ends or do i use passat ones?
Hello. You can use your ball joints and track rods. You just need Passat bolt nuts for them, as they have different design.
On note on the lower arms. With the Passat lower arm you will never achieve a perfect camber. For perfect adjustments, use the Passat spindle combined with Audi TT lower arms and also TT ball joints.
