Electric window height adjustment
donnaile
In: Shadow Blue
Options: heated seats
Post by donnaile »
Hello
Firstly, thanks for adding me to the forum. :yes: I'm a proud owner of a 2010 Scirocco 2.0 TDI.
Recently I had the electric window motor die on the drivers side. Ever since the motor was replaced the wind noise on that side has been terrible. I notice that the window isn't sealing properly. It needs to be bought up by a couple mm.
Question. How do I adjust the window up vertically a few mm? I know you can adjust the tilt on the window from the bottom of the door via two bolts however its the vertical position I'm after. I have removed the door card but can't see anything obvious.
Thanks in advance
Ed
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Re: Electric window height adjustment
Post by davidscirocco »
hi there. i have the same problem but i ordered the the window mechanism as my motor its still working. ill let you know how things went in my case.
PGN
Options: Metallic Paint, Cruise Control, Rear Park Sensors, Foldable Door Mirrors
Dynaudio Package, Tyre Pressure Monitor, Factory Floor Mats
Post by PGN »
Have you tried resetting the window positions?
Do the following:
- Sit in the car with the doors closed
- Switch the ignition on
- Open the window a few inches
- Close the window with the switch all the way in one go and without letting go of the switch continue to hold in the "Up" position for a couple of seconds
- Release the switch and wait a second
- Hold the switch in the "Up" position for a few seconds
- The window should now operate correctly
davidscirocco
sport pack
RCD 510
PGN wrote:Have you tried resetting the window positions?
Do the following:
my case hasn't work...
davidscirocco
sport pack
RCD 510
i got my regulator today and i replace the old one and in my case the old regulator was broken but somehow still worked but wouldn't close the window completely. after replacing the regulator window closes all the way up its just now it need some alignment
