Morning Everyone
I've been searching the internet for last few day trying to find the correct wheel bearing for a 2011 R, however every time i think i'm getting 2 step forward i'm actually going 5 step backs. if possible could someone please let me know what the OEM code is, The one i keep going back to is: 1T0598611B.
Thanks in advance
Heckerz
Wheel Bearing Help
Re: Wheel Bearing Help
Just looked it up on VW's part database (ETKA)
Original Part number was 1T0598611B however this has been superseded with 3G0598611A (which is what you will get when you order from the dealership parts department)
If going third party, then either of those part numbers is fine and will be correct - VW often supersedes parts, much of the time with no difference other than to consolidate part numbers from different vehicles which are actually using the exact same part.
