Passenger door lock, mirror indicator/heater not working.
heves9941
In: Pewter Grey
Post by heves9941 »
I have an issue with my passenger side door:
1. The door doesn't lock
2. The wing mirror indicator doesn't work
3. The wing mirror heater doesn't work
There are no issues with the window on the passenger side and no issues with the driver's side for any of the above.
Any help pointing me in the direction of the problem and/or solution would be much appreciated.
Harry
Winka87
In: Salsa Red
Options: 18" black interlagos, r8 style led drl headlights
Re: Passenger door lock, mirror indicator/heater not working
Post by Winka87 »
Hi did u solve this problem gt the exact same thing on my 11 plate
djharveyz
Options: heated seats
Re: Passenger door lock, mirror indicator/heater not working.
Post by djharveyz »
Hi, was there a fix for this? currently having same issue with my 2010 plate rocoo
bigkris06
In: Pewter Grey
Post by bigkris06 »
I would imagine there is an issue with the wiring between the body and the door. Check the wiring where it goes through for any breaks etc.
Tommohawk
In: Pure White
Options: Sunroof, 19" alloys, leather heated seats
Post by Tommohawk »
djharveyz wrote: ↑Mon Jan 08, 2024 7:42 pm Hi, was there a fix for this? currently having same issue with my 2010 plate rocoo
Hi djharveyz did you get a fix for this mate?
sciroccomods
Options: Mk8 R heated wheel,
Porsche 18z 6 pots
Sequential animated Bi-xenons,
Sequential animated rear lights
Electric cooling/massage/memory Leather seats,
auto dimming power fold mirrors,
virtual cluster,
Dynaudio,
panoramic roof,
Dcc,
Direct tpms,
Blindspot assist,
Acc,
Lane/Sign/high beam assist,
Post by sciroccomods »
If you havent been trying to code then id say either wires in the door connector or door module. if you have been coding and made a mess of it i can give you a new code to change too.
I offer Power fold mirrors installs, Cruise control installs, Coding, mirror folding on keyfob etc. i'm in Stockport,Manchester
Tommohawk
In: Pure White
Post by Tommohawk »
Found out what was wrong with mine, the pins in the door connector were corroded. Took it to an auto electrician and they charged me £140 to tell me that I need to do and order a new wiring loom and door/window motor module. Then they would then recode to the car for £200. I ordered a module for £25 second hand and used it as a donor. I unsoldered the damaged pins and soldered new second hand pins from the donor module and cleaned out the wiring harness connection with electral cleaner and some fine sandpaper. Refitted and all working perfectly. Can't believe dampness managed to penetrate where it was so may be worth checking if anyone else has this issue.
bigkris06
In: Pewter Grey
Post by bigkris06 »
Well done - great fix. I’m sure as the cars are getting older this is going to help other users.
