LED Rear Lights
All the info you need to know about the new VW Scirocco.
Leogeo
Options: R front bumper, rear bumper, rear lights.
LED Rear Lights
Post by Leogeo »
Hi
can someone help, I've recently brought a 2010 scirocco that has had the R bumpers and LED rear lights fitted but not wired.
I'm struggling to find the cables for the rear fog light and saying that the rear fog light.
It it part of the rear LED lights or was is it a separate light set in the bumper etc?
chelspeed
Options: Sold it!
Re: LED Rear Lights
Post by chelspeed »
Foglight is in the main cluster. Just been out to have a look but it's too bright daylight to see and mines facelift so probably different.
There's a lighting section under technical where you'd probably get more response but it's locked down until you reach a set post count (quite low I think). So post a load of bollocks here and fairly soon you'll get access to technical.
Roy_01
In: Sumatra
Re: LED Rear Lights
Post by Roy_01 »
So your rear light aren't working now or only the right rear fog light?
Maybe they put in lhd lights or bulb is not present.
