Hi guys,
Fitted a MK6 wheel today, only issue is the horn isn't working, everything else is including steering wheel buttons.
The only thing that I could think of is that I used my old MK5 airbag loom as some guy had cut the one on the mk6 wheel.
They look identical though but I did read some of the pins may have swapped round, anyone have any ideas or wiring diagrams?
Mk6 steering wheel retro - horn not working
- In: Pure White
Re: Mk6 steering wheel retro - horn not working
Did you change the controller to the CH version?
I did yeah my problem was i used my old airbag wiring which isn't compatible (needs a bit which connects to the horn rail)
