Alloy centre cap
Alloy centre cap
Hi, Some person has pinched a centre cap from one of my alloys
Does any one know how much a replacement will be from a dealer. I thought ebay might have had some but all I can find are some stick on ones. Or are there any aftermarket ones available.
- bianco
Re: Alloy centre cap
My dealer gave me four for the winter tires after I asked politely.
So they are probably very cheap
Hi
There is a company on ebay called dsgwagen which is a main dealer selling the centre caps for £5.50 + £1.25 postage
hope this helps
hope this helps
Thanks for that info
They're £4-£5ish from a dealer
- stan_blade
How easy is it to remove them? as I have a couple of chips on a couple of mine. And if I get any more marks, I may replace them.
cheers
Stan
cheers
Stan
You can lever them out with a screwdriver but you run the risk of damaging either the cap or the wheel - easiest to push them out from behind with the wheel off.
My Roc now has all its caps in place, well until some other thieving sod decides to pinch another
. Thanks to all for the info.
