Notchy gearchange
Gloscs
Options: Sat Nav
Notchy gearchange
Post by Gloscs »
Had my 2011 Rocco for a couple of months now and find the gear change to be rather notchy, a bit mechanical, if you know what I mean. Is this normal, cars done just under 40k.
Thanks for any comments
xjay1337
Re: Notchy gearchange
Post by xjay1337 »
fairly normal.
have linkage realigned.
click for build thread
Mr OCD
In: Shadow Blue
Options: All of them ... lol
Post by Mr OCD »
Re-aligning is easy enough to do yourself.
Gloscs
Options: Sat Nav
Post by Gloscs »
Is there a "how to" anywhere?
xjay1337
Post by xjay1337 »
Its the same as mk5 gti im sure theres a diy for that.
Mr OCD
In: Shadow Blue
Post by Mr OCD »
xjay1337 wrote:Its the same as mk5 gti im sure theres a diy for that.
Gloscs
Options: Sat Nav
Post by Gloscs »
Thanks for the feedback, will try the re-adjustment and feedback if successful or otherwise.
daves2369
Options: APR Stage 1
Heated Viena Leather,
18" interlagos alloys
RNS510,
Bluetooth 9w7,
Milltek Cat Back,
VWR Intake,
Cruise Control,
Parking sensors,
MK5 R32 345mm Setup,
Headlightretrofits bi-xenon
Post by daves2369 »
I have had 3 VW's (MK4 1.4, MK5 2.0 FSI and Scirocco 2.0 TSI) all of them have felt notchy seems the VW way :yes:
Mr OCD
In: Shadow Blue
Post by Mr OCD »
I swapped mine to an Audi S3 short shift .. then set the cables up - its lovely and smooth.
xjay1337
Post by xjay1337 »
Pretty sure the s3 is same as scirocco anyway? Lol
Mr OCD
In: Shadow Blue
Post by Mr OCD »
xjay1337 wrote:Pretty sure the s3 is same as scirocco anyway? Lol
It's not when you compare side by side. :)
http://www.sciroccocentral.co.uk/forum/ ... =2&t=20736" onclick="window.open(this.href);return false;
Although it is only a minor change... but then that is all I wanted after coming from a proper short shifter on my old car.
