N80 EVAP Purgle Valve Open error code
Hi Guys,
Ever since i got a new turbo fitted i'm running into errors.
I just started my car and saw the engine light come up, once i got home i went into vcds and saw that the N80 purge valve was on open.
The code was from 17:11 and the code/light came on at 21:10....
I cleared the code but how do i fix this and what does the valve do?
Help is appreciated and i'm thinking about selling the scirocco.....
Re: N80 EVAP Purgle Valve Open error code
As I understand it the valve controls the vapour stored in the charcoal canister and when open allows it into the intake to allow it to be burnt. It's a relatively cheap part to replace.
Thanks, do you know a part number for this part?Cuprabob wrote:As I understand it the valve controls the vapour stored in the charcoal canister and when open allows it into the intake to allow it to be burnt. It's a relatively cheap part to replace.
I'm searching in etka but i can't seem to find it...
Double check the part number as it may not be the same one as the Golf.
Part No. 06E906517A
Part No. 06E906517A
I'll check if the error comes back and will call the dealer for a price...
I would be surprised if it's more than £25. Obviously check the connections on your current one.
I've checked the etka database with the number you provided.
It's the same as what's in my scirocco
Is this the valve?
http://s16.postimg.org/4nns3jin7/IMG_99 ... 1464611569" onclick="window.open(this.href);return false;
The one at the top of the picture in the middle - yes.`Jestar wrote:Is this the valve?
To get it off the bracket, spray a little oil (wd40 will do) to loosen it up as the rubber bracket that surrounds the valve tends to harden and stick over time.
With the hoses i spray some penetrating oil where they join to the barbs and let them sit for 5 minutes, after removing the hose clip of course - again the rubber sticks and removing them can be difficult.
Replaced it but one of the connector plug cables broke...
Hopefully the garage can solder it together...
Hi,just done check on my engine and have fault code 001092-EVAP purge control valve N80.
So called be dealer to order new one ,gave them exactly part number from old one and they said it’s discontinued.
Apparently now i can't buy the old version which was around £20 , so it’s gonna be over £100 cos it’s totally different setup
After typing on google this part number 06H 906 517H (number from my faulty valve)I got results from bosh 06H 906 517A , so difference its beetwen H and A and wondering if this still would work?
Any help please.
Any help please.
