Met up with a few of the VAG boys at Ladybower in the Peak district and snake road A57, was a very enjoyable drive.
So with most of the cars being Mk5 the Rocco was Bossing.
Very good turn out and the Rocco took center stage
I might actually bring it with me as i dont have time today and tomorrrow its an early start to get to Nikixjay1337 wrote:Fit it before remap!or take it with you im sure niki will fit it!
You're right about the dp.
The start is 3.5inch and then tapers to 3. Important thing is the 3.5 at the flange end so turbo has no restrictions
Plugs into OBD though , and costs more than Polar and is naff! Polar provides far more details and looks better IMO.Psycho Kirky wrote:Im sure P3 do a vent gauge?
Sent Via tapatalk
I will have to check it out!xjay1337 wrote:New south do a gauge that matches OEM cluster
White background blue needle
Thanks for that Mate,xjay1337 wrote:Great result on the dyno mate. Niki certainly does know his stuff :-)
Good thing is if you spend another £500 you'll jump up to about 340! And a further £500 on top and you can be closer to 380 but have huge midrange gains from the HPFP upgrade.
Ebay for the badges.
Regarding the vent, no candoosville. I have looked and tried. I ended up getting a Polar FIS.
