Car is vibrating when idle its like this i uploaded a video...
Only had the clutch and flywheel replaced a week or so ago... :/
Vibrating...
Re: Vibrating...
Was it vibrating as soon as you got it back, or has it recently developed this vibration?
Re: Vibrating...
Happen afterwards just recently.
Re: Vibrating...
Do you have access to vcds scan tool? Kind of hard to understand via the vid. Would a passenger notice the vibrating?
Re: Vibrating...
No access to vcds
a passenger would notice the vibrating as well.
- Gazfay
Re: Vibrating...
Are your engine mounts ok
Re: Vibrating...
As above. The three engine mount bolts on the gearbox are known to work loose.
