Wanted 19" Talladega
Thanks to potholes I need a 19" talladega or a set of 18inch!
Re: Wanted 19" Talladega
Just be aware that if you get offered one off a Golf R it has a different offset.
Sorry to hear about your encounter with a pothole and good luck with your search.
Thanks for your reply. I am aware that I need an ET41 and not ET51 but the ET51 will fit with 10mm spacers. I would consider 18inch for a softer ride!Cuprabob wrote:Just be aware that if you get offered one off a Golf R it has a different offset.
No problem, I didn't mean to patronise you but not everyone is aware there are the same style of wheels with different offsets.
Better to be safe than sorry - the one I have damaged only showed up at the MOT otherwise I was not aware of any problem! - thanks again
found this on amazon - any good? " onclick="window.open(this.href);return false;
roakley wrote:Thanks for your reply. I am aware that I need an ET41 and not ET51 but the ET51 will fit with 10mm spacers. I would consider 18inch for a softer ride!Cuprabob wrote:Just be aware that if you get offered one off a Golf R it has a different offset.
I have just purchased 4 x golf r 19" talladega alloys. I was not aware that the offset was different! Grrr. What would be the implications of fitting these to a scirocco with out spacers? Will they not fit at all? My car is not lowered at all. Must I now purchase spacers? Please help!
Scirocco now gone
