Paradox1 wrote:shrink wrote:Stage 1 is a standard software map. It's not customised for your car, or any other mods you have made, and they could apply it to a car in your local tesco car park if they so desired. No rolling road required.
Tesco Value Remap
Well my Tesco remap went well!
Joking aside, the guys at TC Garage were most knowledgeable and didn't mind me sticking my noise in the remap process. I was very interested in how it all works. There are some custom mods to each map, some have said there isn't but it seem you can adjust fuel, turbo and timing, if I remember correctly over a base map. So depending on what hardware you have, fuel pump, intake these can be adjusted. So I think a rolling road would be helpful but not absolutely essential. A road test was done and all seems ok.
However, once home i noticed that when i'm revving the car to say 2.5k and above, as the revs drop to about 1.5k it gets lumpy to the point that the car shakes a little and the rev counter isn't smooth. Also you can hear that it's not smooth. I called TC Garage and they want to have a look at it, I have to go back as the SPS they had didn't work so a new one is on order. They said they would call back if something was bad happening but did say it will be ok.
So all in all, I'm very impressed with the map, I did get 37+mpg coming home, thats until a chav in a merc wanted a race, couldn't resist, he was history
