Hi.
I have just updated firmware and maps on my rns510.
Everything works fine except the Bluetooth in media is always unselectable. It worked playing music before update and showed band name and track info on the RNS510 display. The phone bluetooth works fine and makes calls without issues.
What do I need to do the have everything paired and working normal.
Bluetooth music
Re: Bluetooth music
I had the same issue and solved it with vcds by going into '77 telephone' bit 5 (or 6, can't remember for sure) and unchecking the box labelled "Bluetooth media inactive" works fine on my car now..
If you do a search then better instructions are on my thread called "finally got Bluetooth audio"
Most scirocco's are all the same but some are different...
Re: Bluetooth music
Thanks. I have tried that but it has not done anything.
I will compare autoscans and try find the issue.
Re: Bluetooth music
I have a similar issue also, playing audio displays as bt-audio on the screen I cant skip or do anything with no track info which is a pain.
