a quick google can't provide an answer...
Is there a recommended mileage for replacing a clutch? I'm getting the dreaded squeel (I don't think it's covered by warranty now due to age, '58 plate?) and thought maybe I could replace it at the same time.
Car is on 66.8k and currently has no sign of slipping clutch.
clutch replacement
Re: clutch replacement
No specific mileage as it all comes down to driving style.
No worries, it is starting to feel a tad heavy and pulling away doesnt feel as smooth but I think some of it could be psychological due to trying to avoid the squeal.
edit:
Also thinking down the road to get a stage1, is a "sports" clutch needed for this?
edit:
it depends on the age of your clutch, but generally no. Upgraded clutch not needed to stage 1.
The squeal itself is usually caused by a leaking slave cylinder which is covered on warranty including the labor then just ask them to fit a new clutch while they are there for parts cost
The slave cylinder leaks onto the release bearing making it squeal eventually wearing it out.
