Hey
Possibly an easy question, but how do you adjust the rear camber?
Rear camber
- keal23
Rear camber
My Progress
http://www.sciroccocentral.co.uk/forum/ ... 13&t=16773" onclick="window.open(this.href);return false;
Instagram - keal023
Instagram - keal023
Re: Rear camber
There are 4 eccentric bolts on the inside of the hub. I would recommend gettin a garage to do it, as it's better to make sure it is alligned to your other side and then the fronts, otherwise you'll end up scrubbing the tyres. I had mine go massively out a couple of month ago. Took it to VW and they told me that it couldn't be adjusted and it was a fixed axle without camber adjust! So much for fully trained technicians! I had to correct them and after an argument they realised!
Anyways its an easy job, but I'd say get a mechanic or somewhere to check they are the same, otherwise you'll be burning through tyres in no time!
