Mapped or not
Mapped or not
Hey all,
Had my rocco 3 weeks now, had new injectors, coils, spark plugs and inlet de-coked.
The speed is incredible, torque steer, wheel spin 1st and 2nd, dry and wet.
So this got me wondering if it's mapped?
And way to tell without asking the garage?
Btw, if you've not had a de Coke done, do it! Transforms the car!
Re: Mapped or not
+1 on decoke!, always said coke is bad for you
Do a few 0-60's, probably easiest and cheapest way to tell if its been remapped.
Re: Mapped or not
Ah! Good point lol. If chipped, what should I expect 0 to 60 times to be?blower wrote:+1 on decoke!, always said coke is bad for you
Re: Mapped or not
If using the speedometer with a manual timer or an OBD2 device then the 0-60 is around 6 seconds with a DSG or a good manual shifter.
The official 0-60 is 6.9 seconds, but that's because its using the real speed - the speedometer is usually between 5 and 10% out, always showing more speed than reality.
Also that's 0-62 and not 0-60.
A GPS based 0-60 timer will give around 6.7 seconds.
All this is for the original 210ps GT 2.0 TSI model.
Basically if you're measuring closer to 5 seconds with a timer and speedometer reading, then you're mapped.
- 3t3p
Re: Mapped or not
whats the de-coking do and how is it done and what are the benefits?
Re: Mapped or not
That's fantastic info, thanks very much.blower wrote:If using the speedometer with a manual timer or an OBD2 device then the 0-60 is around 6 seconds with a DSG or a good manual shifter.
Re: Mapped or not
De coking, clears all the carbon from the inlet, so allows the air to enter the chambers correctly. Also if coked enough the inlet valves won't completely close.3t3p wrote:whats the de-coking do and how is it done and what are the benefits?
I'm sure someone can explain it far better than me though
Re: Mapped or not
You could also check how far she revs up, my 2.0 tsi GT revs to 7k with APR
Re: Mapped or not
I hate bouncing off the limiter thoughdaves2369 wrote:You could also check how far she revs up, my 2.0 tsi GT revs to 7k with APR
Re: Mapped or not
if top end it still feels as quick as it does in low gears then its mapped.
I feel your pain, I had an injector blow last week. Hopefully getting sorted today.
If a care has been decoked, eventually its going to get coked up again. How long would this take?
Re: Mapped or not
susprised you get torque steer. I have an R, which is quite a bit up on power from the GT, and I don't get any torque steer at all, not even hammering it in 2nd.
The day I test drove the R, I test drove a focus ST, and it torque steered like an absolute beast, I found it totally unacceptable.
Maybe the XDS system in the R is tuned more aggressively to deal with the power?
is XDS enabled on the GT as standard?
Re: Mapped or not
Yea I'm surprised re the torque steer, thankfully it's controllable lol
I'll have to try some 0 to 60 at the weekend, maybe I'll get a surprise or two
Re: Mapped or not
worth seeing if you have XDS enabled, and if not, see if someone can enable it for you in VCDS as it will all but eliminate the torque steer. It is completely absent in my RIceash wrote:Yea I'm surprised re the torque steer, thankfully it's controllable lol
Re: Mapped or not
I didn't think the GT Rocco's came with XDS...
Re: Mapped or not
I tried to enable XDS and Hill hold last night on my 2008 GT got coding out of range and an error uninitialised module which nearly gave me a heart attach as my ABS light came on with incorrect coding and couldn't find speed sensor.
Re: Mapped or not
I think it needs 2010+ MY cars
Re: Mapped or not
My understanding is that it can just be turned on, as its simply a function of the stability / ABS program. There are various modes of severity it can be enabled for (e.g. 1, for only light interference, up to 2 for strong) the R comes preset to 2.Paradox1 wrote:I didn't think the GT Rocco's came with XDS...
Re: Mapped or not
I best be looking into that one then. I do have the manual box? Will that make a difference?
Re: Mapped or not
NopeIceash wrote:I best be looking into that one then. I do have the manual box? Will that make a difference?
Re: Mapped or not
Lit them up again this morning, followed a bus into a new road was clear so popped past him, tc light flashing away lol wasn't even floored (1st gear)
