Hi all
My boiler keeps loosing pressure...aghhhhh
I have had the PRV replaced as it was dripping on the outside of the house so suspected the PRV was bust
But this hasn't cured the problem
Any ideas ???
Boiler help.....?
Re: Boiler help.....?
Has the prv now stopped leaking? If so put a bucket under the discharge pipe and make sure it's not opening when hot. If the bucket stays empty then you have a leak on the heating system or boiler (look for water).
If the bucket fills with water then you have probably got a failed expansion vessel. Check this and report back.
might sound obvious, but double check that any boiler filler valves are shut tight.
