New exhaust tips blacking fast, problem or not?
stevencrawford08
Options: Stock 2015 R, heated leather sat nav 19" alloys parking sensors r sills etc
Post by stevencrawford08 »
Hi folks, My car has only covered 500 miles yet the exhaust tips seem to be blacking quite excessively. I am not sure if this is normal and if it is I would be lost as to what cleaning products to use! I also am running the car on 99ron v power nitro if that makes any difference. Advice required!
typical of the tsi and tfsi engines, exhaust sooting. get some autosol metal polish and give them a wipe now and then, should keep them mint; mine were solid black when i got the car, took a few goes to get through it to chrome.
stevencrawford08
Re: New exhaust tips blacking fast, problem or not?
Top stuff mate, I'll give that a look and hopefully get some stuff ordered. Trying to keep it looking perfect! Also that is a lovely example of a Scirocco, Noticed you have the badges blacked out. Did you use gloss black spray/plasti dip and what one?
stevencrawford08 wrote:Top stuff mate, I'll give that a look and hopefully get some stuff ordered. Trying to keep it looking perfect! Also that is a lovely example of a Scirocco, Noticed you have the badges blacked out. Did you use gloss black spray/plasti dip and what one?
cheers! i bought them from ebay for about £20, they're available in gloss or matt black.
Jace
Options: APR stage 2+, APR TBE, APR carbonio carbon intake pipe, VWR Intake, Forge inter cooler pipework, R8 coils packs, Sachs Loba stg2 clutch
Post by Jace »
I use one of these on a cordless drill to sort mine out
http://www.elitecarcare.co.uk/elite-all ... Path=25_30" onclick="window.open(this.href);return false;
AlanH
Options: Nav
Post by AlanH »
Just metal polish of your choice. (I use Autofinesse Mercury)
And some 0/0 grade wire wool and a little elbow grease
Mine: Scirocco 1.4TSi
Others: Fabia MC BE, Citigo BE
Mods: OE sunshades, LED interior/exterior lights, Dectane rear clusters, K&N panel filter, Milltek catbak NR, 35mm H&R springs, 98RON REVO Stage 1, HP Dashcam
stevencrawford08
After this thread and another on pistonheads, I got WD40 and sprayed the exhaust down then gave it a scrub with a brillo-sponge style pad, Then I got autosol metal polish and a microfibre cloth and made a light application with the cloth. They are now very shiny and clean! I reckon the wire wool would be good for heaver soiled exhausts but as long as you keep on top of it I'd say this method has worked a treat for me. Thanks.
aaimson
Options: none
Post by aaimson »
I need to do that to mine, few black marks I just can't get out!
