Illumination of dashboard.
mikezero
In: Indium Grey
Options: 19" Talladega, Leather Interior, Dynaudio, Parking Sensors, Xenons, Cruise Control, Folding Mirrors, MIBII, Pana Sunroof, Park Assist, Winter Pack, DCC, RV Camera, Rear 90% tint, Car Net, Voice Activation.
Post by mikezero »
Hi guys!
Picked up a new facelift R-Line last week and noticed the following.
When I have the sidelights on, the dash cluster is not illuminated.
When the main lights are on, the dash cluster is illuminated.
My dealer says this is normal and not a fault. Can any of you guys assist?
Roy_01
In: Sumatra
Re: Illumination of dashboard.
Post by Roy_01 »
This is normal behaviour. There is a light sensor in the instrument cluster that dims/brighten the lightening. But with the light switch in the off or side light position it wil only light up the needles if you drive trough a tunnel or something to warn you that your dipped beams are not on. The dials are fully dimmed at that time.
You see it often that some stupid people are driving only with their front drl lights on when its dark outside, this is a thing to prevent this happening.
mikezero
In: Indium Grey
Post by mikezero »
Thanks Roy.
This must be a new "feature" then as my 62 plate Roc GT illuminated the dash when 'sidelights' were turned on.
SPEEDDRV
Options: Remapped to 187hp.
Dectane front blinker, piano black interior trim, Eonon head unit, front and rear camera, gloss black rear diffuser, full interior LED, full rear LED bulbs, cold start diagnostic off via ODIS, long press on keyfob to close electric mirrors. XDS on Strong. Many more mods...
Post by SPEEDDRV »
On my 2012 Rocco, when sidelights are on, the cluster IS illuminated but when is on DRL only (daylight or on 0), it's all dark with only needles on.
You see very often a lot of stupid people during night with lights off, only DRL. But that's different. DRL is very bright and people might think it's on dipped beams. Now it's different.
Roy_01
In: Sumatra
Post by Roy_01 »
You're right guys normally the gauge surrounding are lighted when side lights are on.
I heared the behaviour of the instrumentlights are changeable with vag can pro software.
