Can the key fob be set to open both doors??
Gmlyall
Options: Panoramic roof
Post by Gmlyall »
Can I open both doors with one click?? I regularly leave my passenger standing locked out! Thanks for any help!
dimexi
Options: Parking Sensors
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: Can the key fob be set to open both doors??
Post by dimexi »
Yes you can. Access to this feature is available via your MFD menu, under "convenience" IIRC.
Gmlyall
Post by Gmlyall »
MFD menu? Is that the one on the screen on the console? Thanks again!
Yes, the MFD is the screen between the clocks.
If you have highline MFD display it can be changed in the convenience menu within settings.
If you don't have highline it can be changed using VCDS otherwise your stuck with 2 blips of the fob to open both doors.
Mr OCD
In: Shadow Blue
Options: All of them ... lol
Post by Mr OCD »
I've the white MFD but cannot see the option to do this?
Double unlock does my head in... :D
Gmlyall
Post by Gmlyall »
I don't appear to have an option on the display-what is VCDS? Apologies for being slightly clueless!
Viking
Options: None
Post by Viking »
VCDS is a dealer emulated tool (similar to the system the main dealers use). Plug a cable into your laptop, load the software, plug it into your car, and change many settings on your car, clear error codes, change configurations etc. Aslo (erroneously) called Vag Com by some people but Vag Com ceased to exist about 8 years ago when they changed the product and called it VCDS.
I have it here if you're oop north and can do the changes for you if you wish.
Gmlyall
Post by Gmlyall »
Thanks for that. It's in for a service tomorrow-I'll ask then! Thanks again!x
