removing swirl marks!
Hey All
Need some advise, I have been to the polish a couple of times and in this glorious sunshine realised they have damaged my paint!!
Any idea what is the best product to remove minor swirl marks with??
cheers
Zak
cheers
Zak
- chr15
Re: removing swirl marks!
You won't be able to remove them by hand, it would need to be done by someone who knows what they are doing with a rotary polisher such as a proffesional detailer.
If you don't want the cost of that then Autoglym Super Resin Polish has fillers in it so it may reduce the marks slightly but over time they will come back. Another product is Poor Boys Black Hole which could be purchased from online retailers.
Someone posted this before....http://www.theultimatefinish.co.uk/Stor ... ductId=851
Don't know if it's any good.
It will be difficult to remove the swirl marks by hand... if you really wanted to try you could go for something like Meguiars Scratch-X but it will be hard work and it will more than likely just remove some of the very light ones.
You could also try using a pre-wax cleanser such as Dodo Juice Lime Prime, which will help if the swirls are minimal, as this product contains micro-abrasives so has a certain amount of "cut" to it.
Failing that - as Chr15 says - you may need to look at removing them with a machine polisher... if you don't fancy giving it a go yourself, we're full time Detailers and we'd be happy to help!
Hope this helps
Taryn and Jim
Hope this helps
Taryn and Jim
Bilt Hamber Autobalm is an amazing product at hiding swirls. At about £15 I think, its a bargain.
http://www.qualityreflects.co.uk" onclick="window.open(this.href);return false;
Regular work updates here:
http://s712.photobucket.com/albums/ww12 ... yReflects/" onclick="window.open(this.href);return false;
http://www.facebook.com/pages/Quality-R ... 4070809482" onclick="window.open(this.href);return false;
Twitter: @qulityreflects
Any idea where this can be purchased as the swirls on the salsa in the current sunshine are doing my head in!!quality reflects wrote:Bilt Hamber Autobalm is an amazing product at hiding swirls. At about £15 I think, its a bargain.
Available from online stores mostly. Ben at http://www.carnaubawaxshop.co.uk/shop/v ... NvcnRieT0= Is one of the best, very quick delivery too. If you order today you should have it tomorrow.
Read the instructions carefully, the only thing I would say is do not allow it to 'cure' or dry. Only do one panel at a time. Good luck.
any tips about preventing swirl marks in the first place....just got a black scirocco, washed once and it left bugs on bonnet...removed with a wee touch of polish and now the swirl marks appear...used a polish mitt to apply
microfibre wash mitt & two bucket method
trix wrote:microfibre wash mitt & two bucket method![]()
Two bucket method with a grit guard at the bottom of one of the buckets, also i prefer Lambs Wool wash mitt
